Putting status updates on hold
You can put status updates on hold when you need more information about the changes, or more time to review the data before you choose to apply the changes or reject the status update.
- Choose Tools, Approvals, Status Updates.
- On the Group By list, select whether to group the list by Project, Resource, or Review.
- Select the projects for which you want to review status updates.
- Select to view Pending status updates.
- Select the updates you want to place on hold, then click Hold.
You can remove a hold from status updates in the Held view by selecting them, then clicking Remove Hold.
