Remove predecessor relationships
  1. Choose Project, Activities.
  2. Select the activity from which you want to remove a predecessor relationship.
  3. Display Activity Details, then click the Predecessors or Relationships tab.
  4. Select the predecessor you want to remove. To view the predecessor's activity information before removing the relationship, click Go To.
  5. Click Remove, then click Yes.
