Remove successor relationships
  1. Choose Project, Activities.
  2. Select the activity from which you want to remove a successor relationship.
  3. Display Activity Details, then click the Successors or Relationships tab.
  4. Select the successor you want to remove. To view the successor's activity information before removing the relationship, click Go To.
  5. Click Remove, then click Yes.
