Set the default rate type for resource assignments
You can specify a project's default rate type for resource and assignments. The default rate type determines which price/unit is set on the resource/role assignment.
- Choose Enterprise, Projects and display Project Details.
- Click the Resources tab.
- In the Assignment Defaults section, click
to select the default rate type for new resource/role assignments in the project. The list corresponds to the rate types defined in the Rate Types tab in the Admin Preferences dialog box when P6 Professional is connected to a P6 Professional database and in P6 when connected to a P6 EPPM database.
This setting does not affect existing resource assignments.
