Set the project default activity calendar
  1. Choose Enterprise, Projects and display Project Details.
  2. Click the Defaults tab.
  3. In the Defaults for New Activities section, select a default calendar.
Tip:
Click the Options bar in the Select Default Project Calendar dialog box to display global or project calendars.
The default calendar is only used for new activities. Changing this setting does not affect existing activities.
