Sharing your feedback with us
From time to time, we will open a feedback survey through which you can share your feedback about working with P6 Professional. When you log in, you'll see a dialog box asking you to Help Us Improve. You can either take the survey at that time, or you can request to be reminded later.
Alternatively, you can choose to participate in the feedback survey at a time more convenient to you, by opening the Feedback item on the Help menu.
