Using Shortcut Keys
The following tables list the menu options that have shortcut keys. If an option is not listed, it does not have a shortcut key.
File Menu (Alt+F)
| Shortcut | Command |
| Ctrl+N | New |
| Ctrl+O | Open |
| Ctrl+W | Close All |
| Ctrl+P | |
| <F10> | Commit Changes |
| <F5> | Refresh Data |
Edit Menu (Alt+E)
| Ctrl+Z | Undo |
| Ctrl+X | Cut |
| Ctrl+C | Copy |
| Ctrl+V | Paste |
| <Ins> | Add |
| <Del> | Delete |
| Ctrl+F | Find |
| <F3> | Find Next |
| Ctrl+R | Replace |
| <F7> | Spell Check |
View Menu (Alt+V)
| Alt+<F1> | Hint Help |
Tools Menu (Alt+T)
| <F9> | Schedule |
| <Shift> + <F9> | Level Resources |
| <Shift> + <F12> | Disable Auto-Reorganization |
Help Menu (Alt+H)
| Ctrl+<F1> | Local Help |
| Ctrl+Alt+<F1> | Online Help |
