Using Hot Keys
The following tables list the menu options that have hot keys. If an option is not listed, it does not have a hot key.
File Menu (Alt-F)
| Hot Key | Command |
| Alt-F, N | New |
| Alt-F, O | Open |
| Alt-F, C | Close All |
| Alt-F, U | Page Setup |
| Alt-F, S | Print Setup |
| Alt-F, V | Print Preview |
| Alt-F, P | |
| Alt-F, I | Import |
| Alt-F, E | Export |
| Alt-F, D | Send Project |
| Alt-F, H | Check In |
| Alt-F, K | Check Out |
| Alt-F, L | Select Project Portfolio |
| Alt-F, M | Commit Change |
| Alt-F, R | Refresh Data |
| Alt-F, J | Lists the last four projects that were opened and opens the project then selected. |
| Alt-F, X | Exit |
Edit Menu (Alt-E)
| Hot Key | Command |
| Alt-E, T | Cut |
| Alt-E, C | Copy |
| Alt-E, P | Paste |
| Alt-E, A | Add |
| Alt-E, L | Delete |
| Alt-E, O | Dissolve |
| Alt-E, I | Assign |
| Alt-E, I, R | Resources |
| Alt-E, I, L | Resources by Role |
| Alt-E, I, O | Roles |
| Alt-E, I, C | Activity Codes |
| Alt-E, I, P | Predecessors |
| Alt-E, I, S | Successors |
| Alt-E, K | Link Activities |
| Alt-E, V | Unlink Activities |
| Alt-E, W | Fill Down |
| Alt-E, L | Select All |
| Alt-E, F | Find |
| Alt-E, N | Find Next |
| Alt-E, R | Replace |
| Alt-E, S | Spell Check |
| Alt-E, U | User Preferences |
View Menu (Alt-V)
| Hot Key | Command |
| Alt-V, O | Layout |
| Alt-V, W | Show on Top |
| Alt-V, H | Show on Bottom |
| Alt-V, M | Timescale |
| Alt-V, F | Filter By |
| Alt-V, G | Group and Sort By |
| Alt-V, P | Progress Spotlight |
| Alt-V, T | Attachments |
| Alt-V, N | Table Font and Row |
| Alt-V, R | Arrange Children |
| Alt-V, L | Align Children |
| Alt-V, X | Chart Box Template |
| Alt-V, N | Chart Font and Colors |
| Alt-V, H | Hint Help |
| Alt-V, S | Status Bar |
| Alt-V, Z | Zoom |
| Alt-V, E | Expand All |
| Alt-V, C | Collapse All |
| Alt-V, T | Toolbars |
Project Menu (Alt-P)
| Hot Key | Command |
| Alt-P, A | Activities |
| Alt-P, S | Resource Assignments |
| Alt-P, W | WBS |
| Alt-P, E | Expenses |
| Alt-P, D | Work Products and Documents |
| Alt-P, T | Thresholds |
| Alt-P, I | Issues |
| Alt-P, R | Risks |
| Alt-P, P | Set Default Project |
Enterprise Menu (Alt-N)
| Hot Key | Command |
| Alt-N, P | Projects |
| Alt-N, E | Enterprise Project Structure |
| Alt-N, C | Tracking |
| Alt-N, F | Project Portfolios |
| Alt-N, R | Resources |
| Alt-N, O | Roles |
| Alt-N, O | OBS |
| Alt-N, S | Resource Codes |
| Alt-N, J | Project Codes |
| Alt-N, C | Activity Codes |
| Alt-N, C | Calendars |
| Alt-N, E | Resource Shifts |
| Alt-N, V | Activity Step Templates |
| Alt-N, A | Cost Accounts |
| Alt-N, F | Funding Sources |
| Alt-N, U | Resource Curves |
| Alt-N, N | External Applications |
Tools Menu (Alt-T)
| Hot Key | Command |
| Alt-T, S | Schedule |
| Alt-T, L | Level Resources |
| Alt-T, A | Apply Actuals |
| Alt-T, U | Update Progress |
| Alt-T, Z | Summarize |
| Alt-T, Z, O | Open Projects |
| Alt-T, Z, A | All Projects |
| Alt-T, J | Job Services |
| Alt-T, O | Store Period Performance |
| Alt-T, G | Global Change |
| Alt-T, M | Monitor Thresholds |
| Alt-T, I | Issue Navigation |
| Alt-T, P | Reports |
| Alt-T, P, P | Reports |
| Alt-T, P, G | Report Groups |
| Alt-T, P, B | Batch Reports |
| Alt-T, W | Report Wizard |
| Alt-T, P | Publish |
| Alt-T, P, P | Project Web Site |
| Alt-T, P, A | Activity Layouts |
| Alt-T, P, T | Tracking Layouts |
Admin Menu (Alt-A)
| Hot Key | Command |
| Alt-A, U | Users |
| Alt-A, S | Security Profiles |
| Alt-A, P | Admin Preferences |
| Alt-A, C | Admin Categories |
| Alt-A, C | Currencies |
| Alt-A, F | Financial Period Calendars |
Help Menu (Alt-H)
| Hot Key | Command |
| Alt-H, L | Local Help |
| Alt-H, O | Online Help |
| Alt-H, A | About Primavera P6 Professional |
