Standard Toolbar
Use the Standard toolbar to perform standard functions, such as opening, closing, and creating projects. This toolbar is displayed by default.
The following table provides information about each available icon on the toolbar.
| Icon | Function | Displays by default? | Shortcut keys | Corresponding menu command |
Creates a new project. If you set your user preferences to use the Create a New Project wizard when creating projects, clicking this icon launches the wizard. If you set your user preferences to not use the wizard when creating projects, a new project with the default project name (NEWPROJ-n) is added to the list of projects in the Projects window. |
Yes | Ctrl+N | File > New | |
| Launches the Open Project dialog box. Select the projects you want to open. | Yes | Ctrl+O | File > Open | |
Closes all open projects. All open windows that display project-specific data, such as the Activities and Work Breakdown Structure windows, are automatically closed when you click this icon. |
Yes | Ctrl+W | File > Close All | |
| Commits your changes to the database. | No | F10 | File > Commit Changes | |
| Refreshes to display the most current data. | No | F5 | File > Refresh Data |
Tip:
To show icons on the toolbar that do not display by default, you must customize the toolbar.
