Sharing Enterprise Risk Data with Oracle Primavera Cloud
After you have configured enterprise risk data you can send that data to Oracle Primavera Cloud to perform quantitative risk analysis. You can then update P6 with the results of that analysis from Oracle Primavera Cloud and see the results in the pre and post response pessimistic dates fields and pre and post response bars in the Activities view.
To share Enterprise risk data with Primavera Cloud, perform the following tasks:
- Configuring Risk Enterprise Data
- Linking P6 and Oracle Primavera Cloud Applications.Linking P6 and Oracle Primavera Cloud Applications.Linking P6 and Oracle Primavera Cloud Applications.Linking P6 and Oracle Primavera Cloud Applications.Linking P6 and Oracle Primavera Cloud Applications.
- Transferring Data Between P6 and Oracle Primavera CloudTransferring Data Between P6 and Oracle Primavera CloudTransferring Data Between P6 and Oracle Primavera CloudTransferring Data Between P6 and Oracle Primavera Cloud
- Updating Projects With Data From Oracle Primavera CloudUpdating Projects With Data From Oracle Primavera Cloud
