Terminating Document Reviews
You can terminate document reviews that you initiated.
To terminate a document review:
- On the
Navigation Menu, expand
Dashboard. - On the Dashboards page, select a dashboard.
- On the dashboard, expand the Document Reviews portlet.
- In the Document Reviews portlet, click the My Reviews tab.
- On the My Reviews tab:
- Select the name of the document review you want to terminate.
- Click
Terminate.
Tip:
Configure dashboard content to add a portlet to the dashboard if it is not available.
