Searching for Documents
If the content repository is installed and configured, you can search for documents using a basic search with keywords and operators or you can conduct an advanced search and construct more complex search queries for documents.
To search for documents:
- On the
Navigation Menu, expand
Projects and click Documents. - On the Documents page, click the Project tab.
- On the Project tab, click
Search. - In the Document Search dialog box:
Tip:
- From a dashboard, you can search your private documents, and all project documents to which you have access.
- To reset all the settings in the Document Search dialog box, click the Clear Criteria button. To clear the list of documents on the Documents page, click
Search Options and choose Clear Search Results.
