Viewing Documents
If P6 is configured to use the content repository, you can view public documents or your private documents.
To view documents:
  1. On the "" Navigation Menu, expand "" Projects and click Documents.
  2. On the Documents page, click the Project tab.
  3. On the Project tab:
    1. Expand a project and select a document.
    2. Click """"View Options and click either ""View or ""Open.
Tip:
  • If P6 is configured with a content repository and you have the appropriate privileges, you can view documents with AutoVue.
  • You can also view documents from the Documents detail window of the Activities page or the My Documents portlet of the Dashboards page.
