Downloading Documents
If P6 is installed with a configured content repository and workflow repository, you can download a read-only copy of a document to your local machine or another specified location.
Downloading enables you to keep a personal copy of the document and make modifications to it in the document's native application. Any changes you make to the document are saved locally and do not affect the original document in P6.
To download documents:
- On the
Navigation Menu, expand
Projects and click Documents. - On the Documents page, select the Project tab.
- On the Project tab, expand a project, select a document, and click
View Options
Download.
Tip:
You can also download documents from the My Documents portlet of the Dashboards page.
