About Project Scheduled Services
Project Scheduled Services runs a service at the time and frequency that you select for the projects, EPS nodes, project code values, and portfolios that you choose. You can run a scheduled service against both filtered and manually created portfolios. You can schedule the following types of services: apply actuals, export (XER or XML), import (XER or XML), level, project checker, publish, schedule, summarize, and send to schedule sheet. Use this feature to schedule services so you do not have to run them manually.
