Creating Project Scheduled Services
You can schedule services to run at intervals you choose on projects that you select. Available services include apply actuals, delete published data, export, import, level, project checker, publish, schedule, summarize, and send to schedule sheet.
To create project scheduled services:
- On the
Navigation Menu, expand
Administration and click Scheduled Services. - On the Scheduled Services page, click Project.
- Click Add
and select the type of service to add. - Enter a name for the new service.
- In the Project Settings detail window:
- Select or clear the Enabled option to determine whether the service will run.
- Select Save.
Tip:
You cannot schedule services for project templates.
