Selecting Baselines for Scheduled Services
Select baselines for scheduled Publish and Export Primavera XML services to control which baselines the service includes for projects selected directly or resolved from EPS nodes, portfolios, or project code values.
Before you can select the baselines to include with a scheduled service, you must select the projects to include, either by selecting projects individually, selecting an EPS node, or selecting a project code that identifies the projects the service will include.
To select baselines for a scheduled service:
