Configuring Project Scheduled Services
You can configure the name, time, frequency, projects, and settings for a scheduled service.
To configure scheduled services:
  1. On the "" Navigation Menu, expand "" Administration and click Scheduled Services.
  2. On the Scheduled Services page, select Project.
  3. Select a service.
  4. Select or clear the Enabled option.
  5. In the Project Settings detail window:
    1. Configure the fields and lists.
  6. Click Save.
Tip:
Services for project templates cannot be scheduled, they must be run manually.
