About Administration
Administration allows you to control access to features and configure global preferences for all application users in P6 and P6 Professional. The Administration Page allows you to configure:
Many of the features described in this section require additional settings to be configured in the P6 Administrator application. See the P6 EPPM System Administration Guide.
Application Settings: Presents options to specify default administrative preferences established by the P6 Administrator.
Enterprise Data: Presents options to configure the essential application framework your users will need to manage all projects and is established by the P6 Administrator.
Scheduled Services: Presents options to configure services that run at scheduled intervals to perform certain functions against the database or specific projects. You can configure the time and frequency that Global Services run and you can enable or disable each global service individually. You can also create Project services to perform specific actions, such as summarizing, publishing, exporting, or scheduling specific projects.
User Administration: Presents options to add users, configure what features a user can access and view as established by the P6 Administrator, assign Organizational Breakdown Structures (OBS) to users, configure module access to P6 EPPM applications, and add project and global security profiles to users.
User Interface Views: Presents options to configure how users see the interface view so the user can view only the selected features established by the P6 administrator.
