About My Preferences
My Preferences offers options for you to customize the data display format across all sections of P6. The options you customize are exclusively yours. You can alter global preferences, including formats for time units, dates, and currencies. You can also customize view preferences if the P6 Administrator gives you access to do so. Some view preferences you can customize include menu items and pages. You can also change your password.
