Customizing My Preferences Global Preferences
Customize global preferences to create a working environment that suits your needs. The global preferences you select affect only your interaction with the application; other users are not affected by your changes.
Global preferences is broken down into several sections. To see how to customize a section, use any of the tasks listed below.
