Customizing Global Currency Preferences
Customize currency preferences to determine how currency is displayed in the application.
To customize currency preferences:
  1. Click the User menu and select My Preferences.
  2. On the My Preferences page, click the Global tab.
  3. On the Global tab, select Display Format.
  4. In the Currency field, select "" Select.
  5. In the Select Currency dialog box, select a currency and click Select.
  6. On the Global tab, select the Show decimal places and Show currency symbol options to suit your needs.
  7. Click Save.
Tip:
You can double-click the Currency field and type a currency name rather than search for a currency.
