Customizing Global Date Format Preferences
Customize date format preferences to determine how dates are displayed in the application.
To customize date format preferences:
- Click the User menu and select My Preferences.
- On the My Preferences page, select Display Format.
- On the Display Format tab:
- Click the Date format list, and choose a format.
- Select Four digit year, Month name, Leading zeros, and Separator options to suit your needs.
- Click the Time format list, and choose a format.
- Select the Show minutes option if you want minutes to display.
- Click Save.
