Customizing Email Notification Preferences
Customize email notification preferences to enable sending an email to users when issues are created or modified, and sending an email to resources upon adding or removing assignments.
The P6 Administrator must setup an email server for this functionality to work.
To customize general preferences:
- Click the User menu and select My Preferences.
- On the My Preferences page, click the Global tab.
- On the Global tab, select Email Notifications.
- In the Issues section, configure when you want to receive email notifications about issues.
- In the Resource Assignments section, configure whether you want to send email notifications to resources when adding or removing resource assignments and whether you want to receive a prompt before sending those emails.
- On the Global tab, click Save.
