Customizing Global Performance Threshold Preferences
Customize performance threshold preferences to specify parameters for Performance, Earned Value, and Index values that appear in dashboard Project Performance portlets and on the Portfolios Performance Status tab.
To customize performance threshold preferences:
- Click the User menu and select My Preferences.
- On the My Preferences page, click the Global tab.
- On the Global tab, select Performance Thresholds.
- In the Performance Thresholds section:
- In the Performance subsection select a value for each field.
- In the Earned Value subsection select a value for each field.
- In the Index subsection select a value for each field.
- On the Global tab, click Save.
