Customizing Project Score Preferences
You can customize your own project score preferences to determine how the project will be scored in the application.
To customize project score preferences:
  1. Click the User menu and select My Preferences.
  2. On the My Preferences page, click the Global tab.
  3. On the Global tab, select Project Score.
  4. Select the option to Calculate Project Score based on selected Project Codes if you want to specify which codes P6 uses to calculate Project Score. If you select the option:
    1. Select Assign....
    2. In the Select Project Code dialog box, select a project code and select Select.
    3. Assign more project codes if required.
      If you do not select the Calculate Project Score based on selected Project Codes option, all Project Codes assigned to the project will be used to calculate the Project Score.
  5. In the High is greater than or equal to field, enter a value.
  6. In the Medium is greater than or equal to field, enter a value that is also less than the High is greater than or equal to field.
  7. On the Global tab, click Save.
