Customizing Global Resources Preferences
Customize resources preferences to determine how resources will be displayed in the application.
To customize resources preferences:
- Click the User menu and select My Preferences.
- On the My Preferences page, click the Global tab.
- On the Global tab, select Resources.
- In the Resource Assignments subsection, select one option for each of the statements.
- In the Resource Staffing subsection, select the options.
- In the Number of available items to search for Roles, Resources, and Resource Codes field, enter a value.
- On the Global tab, click Save.
