Customizing Global Row Number Preferences
Customize row number preferences to determine the maximum number of rows that can be displayed in the application.
To customize row number preferences:
Tip:
- If the number of items exceed the maximum you specify for Maximum number of rows displayed in each section, a Next link appears for you to navigate to the next page of the list.
- If the number of items available to display exceeds the maximum you specify for Maximum number of rows displayed in trees and pick lists, a message appears to inform you that you are viewing a partial list.
- The Maximum number of rows displayed in each section setting is used to determine the maximum number of rows in Earned Value Performance dashboards, the Index Performance dashboard, and the Schedule Performance dashboard portlet. The Maximum number of rows displayed in trees and pick lists setting is used to determine the maximum number of rows in the Open Project dialog box, the Global Calendar page of Enterprise Data, and the Resource and Resource Team pickers in Resource Administration.
