Customizing Global Time Units Format Preferences
Customize time units format preferences to determine how time will be displayed in the application.
To customize time units format preferences:
  1. Click the User menu and select My Preferences.
  2. On the My Preferences page, click the Global tab.
  3. On the Global tab, select Display Format.
  4. In the Duration Format section:
    1. Select a duration unit in the list.
    2. Select whether to show duration labels.
    3. Select whether to show sub units.
    4. Select how many decimal places to show.
  5. In the Time Units Format section:
    1. Select a time unit in the list.
    2. Select whether to show unit labels.
  6. Select whether to show units/time as a percentage or as units/duration.
  7. On the Global tab, click Save.
Tip:
You must select Show duration label or Show unit label to select the corresponding Show sub units option.
