About Assignments Views
Assignments Views are the visual layout of resource assignment and role assignment information. You can customize each view according to your needs, including changing the grouping, column selection, column label, and visual display options. Selecting an appropriate view, or customizing a view can facilitate the process of recording resource assignment data. For example to ensure resources are being used effectively, you might include units columns in a table view grouped by resource or role.
