Exporting Views
Export views to share them with colleagues working in another P6 system.
To export views:
- On the
Navigation Menu, expand
Projects or
Resources.-
If you expanded
Projects, click Activities, EPS, or Assignments.
If you expanded
Resources, click Assignments.
If you expanded
- Click the Views
menu and select Import/Export Views. - Click the Export tab.
- On the Export tab:
- In the download window, specify a location and name for the file.
