About P6 Help
Use this online help system to learn more about the P6 application. Context-sensitive help is available from almost every screen by clicking its Help link or Help button.
Use the Table of Contents, Search, and Related Topics features to find the topics of most interest to you and your team.
The help files include information about all features; however, each user might not be authorized by their administrators to access every feature. The help files are written as if you have the access settings required to perform the task or view all the screen elements. If you cannot perform a step or view an element, try adjusting your security settings. Your access to data and ability to interact with the user interface are controlled by various security features. See About Security.
