Viewing Help Content
As you work in the application, there will be times when you need assistance, on varying levels. You might need just a reminder or a complete series of tasks to follow step by step. Refer to the information below if you need help as you work in the application.
- Consult your internal procedures. Your organization might enforce certain rules and policies that override any instructions provided by Oracle.
- If you want to access the P6 Online Help system, consult the table below to determine how to open it from your current location in the application.
| Current Location: | How to Open the Online Help: |
| a page or tab | Click the Help link at the top right of the page. |
| a dialog box | Click the Help button, if available. If no help button is available, try searching for the name of the dialog box as stated in the titlebar or use the related topic links provided for similar topics in the Online Help. |
| a dashboard portlet | Click the Help button in the portlet's titlebar. |
| a detail window (panel) | Click the Help link at the top right of the detail window's parent page and then click the link for the detail window in the Online Help. |
| a work area in full-screen view | Exit the full-screen view and click the Help link at the top right of the page. |
