About email Notifications
Notifications is a feature that enables users to be contacted by email when changes occur relating to project data such as issues or timesheets. For example, you can be notified when a timesheet is awaiting your approval.
When new user accounts are created, the user's email address can be stored. This allows them to receive email notifications when certain events occur such as when a user also mapped to a resource is assigned to an activity. Using issues as another example, users can be notified about issues when the issue's priority level is set to "high", when a specific issue code is assigned, or when any change to an issue occurs.
Email notifications can be sent manually or configured to be sent automatically by the application.
