Printing Pages Using Your Web Browser
Because P6 runs inside your web browser, you can print data using your browser's Print command. P6 application pages also feature a Print link you can click. In addition, many pages also include separate Print icons in a toolbar.
Whenever they are available, the printing commands provided by the application offer the best options and output. You can use the Print Preview feature before generating output.
To print data:
  1. On any page that supports printing, select your browser's Print item.
  2. In the resulting Print dialog box for your operating system, choose a printer and click OK to print.
Tip:
  • To refine the output, use the options available in your browser's Print Preview and Page Setup dialog boxes.
  • The Gantt chart only prints if it is showing in the view.
