About Enterprise Data
Enterprise data is a defined series of application-wide parameters and values that apply to all projects. Your organization can use these settings to customize your projects to meet specific project management requirements and standards. While all users can view these settings, a user must have the proper security privileges to edit them.
The P6 Administrator uses enterprise data to define standard categories and values you can apply across all projects, including custom categories and category values for projects, resources, and WBS elements.
