Configuring Time Periods Settings
Configure time periods settings to specify time period abbreviations and the default number of hours in a work period. The Hours per Time Period are used as conversion factors when users choose to display time units and durations in units other than hours. For example, if the default Hours/Day is set to 8.0, when a user enters 1d as a duration, this value is stored as 8h in the database.
To configure time periods settings:
- On the
Navigation Menu, expand
Administration, then click Application Settings. - On the Application Settings page, click Time Periods.
- On the Time Periods page:
