About EPS Views
EPS views are the visual layout of project and EPS node information. EPS views are customizable; you can change their filters, Gantt chart options, column selection, column label, et cetera. Selecting the best view or customizing a view that suits your needs can facilitate the process of recording project data. For example, to quickly record a range of details for a project or projects, you might select a table view which maximizes the number of data columns available.
