Configuring EPS Views
Configure EPS views to define how you see EPS and project data. EPS views affect the filters, grouping, columns, et cetera that are applied to the EPS page. Detail window visibility is also affected by the selected EPS view.
To configure EPS views:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
- You can modify any view you create. You can only modify multi-user and global EPS views if you have the appropriate security privileges.
- Many of these configurations, configuring columns and filters for example, do not require you to open the Customize EPS View dialog box. If the necessary icons are available on your toolbar, you can use them to configure the EPS view.
