About Future Period Planning
Future Period Planning allows you to represent work patterns which cannot be represented by a linear spread of units or by applying a curve to an assignment. You can enter the planned and remaining resource or role allocation per assignment in the Spreadsheet, then compare the planned future period resource distribution to actual units and costs in the Resource Usage Spreadsheet, Activity Usage Profile, and time-distributed reports.
Future Period Planning is possible for assignments to activities with a duration type of Fixed Duration and Units or Fixed Duration and Units/Time.
