About Issue Codes
For example, you can create an issue code titled Severity, and subsequently create issue code values: High, Medium, and Low. You can assign each of these code values to issues across multiple projects, enabling you to categorize each issue according to how severe it is. Similarly, you can create codes to categorize issues by responsibility, subproject, or any other classification you require to organize issues. Assigning issue codes enables you to quickly search for and view issues according to specific criteria.
