Assigning Issue Codes
You can assign issue codes to organize and categorize issues in a way that is meaningful to you.
To assign an issue code:
  1. On the "" Navigation Menu, expand "" Projects and click Issues.
  2. On the Issues Management page, expand a project and select an issue.
  3. In the Codes detail window click Assign....
  4. In the Select Issue Code detail window, select a code and click Select.
  5. Click Save.
Tip:
  • You can only assign one issue code at a time. Click Assign... again to assign another code.
  • You can also assign issue codes from the My Issues portlet on the Dashboards page.
