About Locations
A location is a geographical reference defined by a pair of coordinates; longitude and latitude.
To create a location, you can enter its coordinates directly or enter a street address and allow P6 to find the longitude and latitude for you.
Assign locations to projects, activities, and resources so you can later use Primavera Analytics to produce powerful, interactive, graphical reports based on geographical location. In Primavera Analytics you can drill down to view data by country, region or city. This can make it easier to show large amounts of data in a relatively small area. Because the data is shown graphically, it also makes it easier for you to see trends and relationships.
You can also sort the Activities, EPS or Resources views by location and can group and filter by location in the Activities and EPS views. The assignments view cannot be grouped or filtered by location.
