Creating Locations
Create locations to assign to projects, activities, and resources so that you can report by location in Primavera Analytics.
To create a location:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Global and click Locations.
- On the Locations page, click
Add. - In the Add Location dialog box:
- Click Save.
Tip:
When you import a project in Primavera XML format, if you choose to import locations any locations assigned in the project will be imported. If any location in the project does not already exist in your database, it will be created.
