Importing Locations
You can import new locations into P6 from a Microsoft Excel (.xlsx) file.
To import locations:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Global and click Locations.
- On the Locations page, clickActions
and select Import from Excel. - In the Import Locations dialog box:
- In the Import File field, click
Select and select a file. - Click Import.
- In the import confirmation message box, click OK.
Tip:
- Click Actions
and select Create Import Template to download a template file ready for you to populate with data.
- When you import a project in Primavera XML format, if you choose to import locations any locations assigned in the project will be imported.
