Creating Import Templates for Importing Locations
Create a Microsoft Excel template to use when importing location data.
To create an import template:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Global and click Locations.
- On the Locations page, click the Actions
menu and select Create Import Template. - In the File Download dialog box, click Open to modify the template or click Save to save it.
Tip:
- The import template is created as a Microsoft Excel file with the default file name, ExportDataToSpreadsheet.
- The top two rows of the spreadsheet are required when importing data locations from a spreadsheet. Do not change the data in these rows.
