About Resource Analysis
The Resources Analysis section enables you to compare resource utilization between resource teams, project resources, and department resource all from one central location using the Role and Resource views.
The chart area offers the option to view data as a histogram, stacked histogram, or area chart to help you examine allocation data for individual resources, as well as total values for resource teams and resource codes.
You can view resource allocation as a spreadsheet (of resource allocation values by project). You can view totals for an entire resource grouping (for example, primary role, resource code value, or resource team) or for individual resources.
You can also choose to view rolled up values for assignments in projects you do not have permission to access. This option does not give you access to those projects or any of their data. Instead it provides totals for the units each resource contributes to those other projects and indicates whether the resource contributes to the costs of the other projects.
You can customize the view on these tabs to view resource information specific to your needs.
