Analyzing Resource Allocations
Use this procedure to analyze resource allocations. The Resource Analysis page offers chart options to help you examine allocation data for individual resources, as well as total values for resource teams and resource codes. Chart data reflects remaining plus actual summary values.
You can customize options, along with filtering and grouping capabilities, to help you focus on the data you want to see.
To analyze resource allocation:
- On the
Navigation Menu, expand
Resources and click Analysis. - On the Analysis page, click the Resource button.
- On the Resource view:
- In the Customize View dialog box:
Tip:
In a histogram or area chart, move the mouse over the corresponding area or bar to display numeric allocation totals for a project or project code.
