Accepting Team Member Status Updates
To accept status updates:
- On the
Navigation Menu, expand
Approvals and click Status Updates. - On the Status Updates page:
- To accept a single update, on the status update card, select Accept.
- To accept all status updates, including any override updates you made, select Accept All.
Tip:
Pending updates for a project checked out in P6 Professional or opened exclusively are not displayed until the project is checked in or the exclusive lock is released.
