Rejecting Team Member Status Updates
To reject status updates:
- On the
Navigation Menu, expand
Approvals and click Status Updates. - On the Status Updates page:
- On the status update card, select Reject.
- In the Reject Status Updates dialog box, enter a Reason for Rejection against each of the fields you require to be changed.
- In the Comments field, enter your overall comments to the team member about this status update.
- Select the Notify team member by email option if you want the team member to receive an email about the rejected status update.
Tip:
- To reject all status updates visible in the view, including any override updates you made, select Reject All.
- Pending updates for a project checked out in P6 Professional or opened exclusively are not displayed until the project is checked in or the exclusive lock is released.
